Hi all,
Posted last week on my underfloor installation and asked questions about vented \ pressurised - had another heating engineer round this morning and have had conflicting advice!
The system: Y plan vented, downstairs boiler, upstairs cylinder with adjacent 3 port valve and pump, 8mm micro bore system installed 1986, Worcester 24ri and fast recharge cyclinder installed 2009, 13m2 area of UFH in new conservatory, immediately behing the wall the boiler is fitted on.
Engineer 1: New pump required by boiler, flow for UFH MUST be taken off after pump or new UFH pump and existing pump will conflict. UFH pump and manifold to be installed by boiler. Need to convert from vented to pressurised heating and hot water system, so new expansion vessel & water cylinder required. Convert from Y plan to S plan to allow independent control of UFH; installation of zone valve by boiler to create Y-plan plus won't work. Old microbore likely to be fine operating under pressure.
Engineer 2: location of flow \ return on boiler is ideal, no new pump required. UFH pump and manifold to be installed by boiler. Advisable to convert heating side to pressurised (although may not strictly be required as three storey house and head 9 - 10 meters from heating header tank to UFH install, so likely to be operating near 1 bar downstairs anyway). Leave hot water side gravity fed, no need to change the cylinder. Expansion vessel required for heating if convert to pressurised. Install one new zone valve to allow independent operation of UFH to create 'Y-plan plus' - no advantage converting to full s-plan. Old microbore also likely to be fine operating under pressure.
Both reputable and experience UFH installers, and both quite insistent they are right!
3rd guy coming round Tuesday for last quote....maybe yet another way to do it!!
What I want is a system that works, if it requires a more complex install to achieve that, then so be it!
Any thoughts - cheers
Philip
Philip
