Hi guys,
Need some advice. The situation is as follows.
I have radiators upstairs in the house, controlled by their own control panel (allowing me to set the times that they come on). This works perfectly. If I override the setting, the boiler comes on and they fire up.
Downstairs I have underfloor heating. This "used" to come on when the thermostat indicated, you know, like 19 degrees, heat up. Downstairs also has a digital timer for controlling the hot water and underfloor heating.
The hot water works perfectly - so if I override it on the digital panel, the boiler kicks in straight away.
The issue I have is that the underfloor heating does not come on! It used too! I have set the digital timer to continuous, I have changed the thermostat (as it was suggested the old one could be faulty). When I set the thermostat to say 23 degrees or hotter, I hear the pump upstairs do something, but then the boiler does not start up.
I have a suspicion that it's down to a faulty motorised zone valve. But as I am not this way trained, I am unsure.
Some details :-
Thermostat is a DT90E
Motorised zone valves (3 of ) are V4043
Digital Timers are ST610)C
There is a Honeywell Wiring Centre involved too. I have uploaded 2 of the underfloor heating diagrams for help!
Basically the question is what could be wrong? Where do I start?
[ View media item 16945 View media item 16944 [/img]
Some details :-
