Right, so over the holidays I'm planning to get some of the plumbing ready for the ufh system that will go in soon. So far I've decided where the manifold is going to be situated and I plan to run a set of flow and return pipes from the boiler. I have a valiant combination boiler which I plan to use with my ufh system and radiators. I've read that I will need a 2 port valve to control the flow in the 2 circuits but where in the system should this be installed? On the ch or ufh side? I'm assuming this is on the flow side.
Also any control systems that can control the ufh and rads you guys can recommend? Or do I have one for the ufh and another for ufh?
