I've been asked to quote for heating an office space-new build-it should be having underfloor heating-but there is only room for 75 mm absolute max screed,as is common practice,the insulation is under the slab.The buider has been told that this is ok as the slab willbecome part of the thermal mass.The systems I have been involved with in the past are the john guest speedfit and hep2o.When I checked with speedfit,they were very clear thet a thin ( v.expensive) insulation layer must be incorporated between the ufh pipes and the slab.As the cost of this insulation is £1200 or so I wondered if any one out there had hit this problem before,Any thoughts much appreciated
