I have a Polypipe wet UFH system which heats a large new extension (5 circuits off manifold) and an old study where the floor was relaid (2 circuits off manifold) with 100mm of insulation over concrete and under the screed. It works well in the extension, but will not heat the study.
The boiler's been running 24/7 for days and the room temperature refuses to lift above 15 degrees, in fact it's now fallen below that. It's about 4m x 2.2m, with 2 circuits of pipe, the temp on the mixing valve is set to 50c and the pump to 2. Flow rate is just below 2. The room has carpet and underlay on the floor (I checked and was sold special (more expensive!) stuff suitable for UFH). Admittedly it's an old room with solid walls and 2 windows, one of which is single glazed and bearing the brunt of the east wind.
The carpet feels warm to touch, but tbh there is very little difference in temperature between the flow and return pipes on the boiler side of the manifold, while the excess heat is gently warming the upstairs rads through a reverse flow on the return circuit.
I can't find any recommendations for the correct flow rate, but am wondering whether to try reducing it so the floor can absorb more of the heat - or is there a limit to how much it can hold and dissipate?
Any suggestions gratefully received thanks.
