Hi all, have a wet underfloor heating system. the issue i have is that some rooms/loops work fine and others the floor stays stone cold. new pump was fitted and the supply is hot so no issues there. blending valve set to 45/50 and the flows all read about 2ltrs.
the returns come back luke warm. if i up the flow and crank up the blending temp the return temp is really hot so water is obv circulating ok. what could cause some of the loops staying stopne cold? i have tried running water via the filling and draining loop etc to flush out air and not helped. also one of the loops' flow valve is stuck at a reading even tho the loop is closed and the heatring system is off. when i tried to flush water through that loop it still stayed in its stuck reading.
