Just moved into a new place with combi boiler and underfloor in one room (extension). All rads have TRVs and the only thermostat (towerstat RSP) in the house seems to be linked to the underfloor heating – would this be logical? I say that as it’s located right above the system and is powered from the same junction box as the pump
Boiler/rads are working fine as we program boiler to come on and control temperature via the TRVs but as yet can’t work out how to use the underfloor. Warm water (but not hot) is going into the system via the copper pipes on the left but that’s all I know
Is there anything you could recommend I check to see if there’s something wrong with the thermostat, pump or anything else?
