I need some advice on the powering of an underfloor heating pump off of a Worcester 24cdi boiler. I have the mixervalve and the pump assembly attached to the heating circuit and the boiler. I just need to know the best way to power up the pump.
I can see the terminals on the boiler that drive the internal pump, and I am sure they will carry enough load to drive the second pump. The problem is that the internal pump will run when the boiler is in hot water mode as well as heating mode. Would it be ok to run this U/F pump at the same time?
Martin
Martin
