I'm about to have a conservatory fitted which is just over 5m x 3m. As part of this I'm having a new boiler fitted as it's in the way at the moment.
The builder who is doing the base and walls etc has just asked if I want underfloor heating, and I hadn't thought about it at all!
I've heard that it's cheaper to run than most types of heating and could make the conservatory a much more comfortable place so we'd use it more and get better value for money.
So first of all the plumber has spec'd up a Glow-worm 24Hxi Boiler to Replace our Ancient Glow-worm Space Saver 38. Is that a good replacement? I'm trusting him there as I have no idea! We've got a boiler scrappage scheme voucher which makes things cheaper!
Our house is a 4 bedroom detached.
Also would the boiler be suitable and up to the job of also doing underfloor heating? We asked for it to be spec'd up to do 2 extra radiators so hopefully will have enough capacity.
And final question are there any good / bad UFH kits to avoid/go for?
We also have a utility room and downstairs toilet which I will be redoing once this is complete, these could also have under floor heating (currently have no heating). Not measured but I would say together they are no more than 10m2
I initially found this kit:
http://www.floorheating.com/products.php?CAT_ID=51&SUB_ID=53&P_ID=286
Which I thought maybe looked a bit weak? Would it be OK for just the conservatory? The price is what attracted me!
I then wondered if something like this would be better:
http://www.floorheating.com/products.php?CAT_ID=51&SUB_ID=53&P_ID=289
It does upto 30m2 (22.5m2 using closer pipe layout) and is in 2 zones so should be able to do the conservatory on one zone and the toilet/utility on another.
It just seems to be lacking info, is it all set mechanically in effect like another radiator? Would this be sufficient?
Any other tips etc?
Many thanks
Any other tips etc?
Many thanks
