Hi all,
As you may have seen from my many threads with questions (Sorry!!) I'm building a garden office, by converting a log cabin (using celotex insulation, 50mm on walls, 100mm on floor/ceiling).
I'm trying to decide what route to take for heating.
Originally my options were underfloor, electric (oil filled?) radiator or a wood burner. I've ruled out the wood burner as its simply not practical. They take up too much room, and after getting the heating requirements back for my room at 1kw, the smallest log burner I can find is a 2kw output, which will be major overkill.
So I'm back to underfloor (electric) heating and oil-filled electric radiators.
Now, I've not got electric sorted out yet, I'm having an electrician round once the structure is in place, from what I understand the oil-filled radiators need a lot more power (e.g most are 2kw). The underfloor heating is 140w per square meter, and will be covering 8 square meters, so that comes in at 1.12kw - this is for one of the newer style underfloor heating systems that heats up in 3 minutes, not one of the old ones that takes an hour.
What would you go for, and why? I'm leaning towards underfloor as the biggest complaint people seem to have with garden offices is that the lower half of the building stays cold all the time, underfloor heating would obviously tackle this, but I dont know if it'll be powerful enough to warm the whole room.
The structure size is 12x8, however it'll have internal walls/insulation added so this size on the inside will be reduced a bit.
Many thanks!
Many thanks!
