- Joined
- 30 Sep 2004
- Messages
- 126
- Reaction score
- 1
- Country
We have two upstairs bathroom with tiled floors laid on plywood boards over the existing floorboards. In one of them a lot of the pipework to the hot water cylinders and towel rails runs under the floor and as a side effect the floor is always warm.
In the other, there are no pipes and the floor is cold.
To avoid ripping up the tiles I was hoping to somehow achieve the same result as the first bathroom has (accidentally). I was thinking to approach from an adjoining room and run hoops of copper pipe parallel to the joists and connect up to the heating water circuit. A friend recommended to use plastic pipe to make it easier to pass them along, but I am not sure if they will release enough heat.
Is this sort of thing anyone else has tried or any other ideas ?
