Underfloor heating zone valve
6 Feb 2010
Blackpool
Does the zone valve on the boilers flow to the underfloor heating manifold usually go near the boiler/heat source. Or near the ufh manifold? Thanks
Best near the others - all labelled up, maybe with a sketch showing the ufh thermostat if there is one, etc.
My preference is as close as poss to the UFH manifold, allows everything for the UFH to be held together. A lot of the UFH valves are also run from the UFH control centre and that is usually close to the UFH manifold too to minimises cable runs but it all depends on locations of each item.
That being said I have to agree with @Exedon, in the grand scheme of things and how the system works it doesn't really matter where it's located, as long as it's clearly marked if it's not apparent. Same with all the other valves.
