Underfloor heating...?
6 Aug 2009
Berkshire
Hi guys...
building an extension at the moment and am wondering about underfloor heating for the kitchen diner which is approx length 3.5M X width 5M.
I have no ideas about pros / cons, costs and how I would go about doing this.
Would be grateful for any advice...
thx
Pro's: tiles are nice and warm on your feet, and no rads in sight.
Con's: time lag of up to several hours (3-4 is possible) between turning on and the room nice and warm.
Therefore it needs a completely independent additional set of controls, time and stat.
10 times more expensive than rads to install.
Very hard to correct if it turns out that something was not installed correctly.
The thermal time constant is also causing it to waste all the heat for 2-3 hours AFTER its needed while its still hot.
Best for retired people who need heat all day long.
Heat output is also only about 0.05 kW per m² and thats often insufficient for smaller rooms. Best for schools, libraries and care homes.
Tony
thank you gents...I was initially against the idea but wanted to make sure as I have the opportunity now to install.
Appreciate your responses...
V
