We plan to install Warmup foil heaters in our lounge (under laminate). We need coverage of 19 square metres, so plan to install two 140W heaters: a 12 square metre and a 7 square metre for a total of 11.56 Amps according to page 6 of the manual: http://www.warmup.co.uk/assets/Uploads/Warmup-foil-heater-manual-v2.pdf
I know the system must be protected by a dedicated 30mA RCD, however we live in a relatively small 3 bed flat atop a very old house. There are no spare ways on our existing 8 way consumer unit, and even if there were it would be very difficult for us to run cable directly from there to the lounge. With that in mind I was looking for alternative solutions, one of which appears to be an RCD fused spur, e.g. http://www.fountaindirect.co.uk/warmup-rcd-fused-spur.html
Are there any issues powering the heaters through an RCD fused spur taken from an existing wall socket? Or we could sacrifice the wall socket if needs be if that's a better alternative? Also could anyone clarify where we stand from a Part P perspective?
Appreciate the help. I know the final connections have to be made by a qualified electrician, tested, certified, etc. We had an electrician round this morning, unfortunately he wasn't the most dynamic of individuals. He said the above approach could work after I suggested it to him, but he didn't fill me with confidence! Just want to make sure eveything is being done in the right way.
