We have a 1930`s solid brick wall house that is on a hill, the front of the house is level with the road out front and the ground level of the garden is about 10ft below the back door, so we have a large void under the house.
I have fitted 100mm of solid urethane type insulation under the floor between the floor joists
We still have draughts, when I fitted laminate flooring in the living room I used silicone around the edges, I`m possibly going to do that in the other room but laminate is already down so it would be on top and possibly a bit messy
would I be able to put foil backed bubble stuff across the floor joists over the insulation, there is good air flow under the floor, would I be better using a breather type membrane and using some kind of expanding foam at the edges
I already have about 25sqm of the bubble foil stuff
Ta
Ray
Ta
Ray
