Underfloor Insulation - Do i need DPM
14 Oct 2022
Hi I am wanting to insulate my suspended wood floors. Taking floorboards up at the moment is not an option.
I have room underneath to do this so was going to use wool insulation and either netting or breathable membrane to hold it in place.
My concern is a few videos I have seen want you to install a dpm between the insulation and floorboards to reduce moisture build up.
Is this correct as would have to take floorboards up then or is it overkill for a 1930 semi?
You don't need a dpm in a suspended floor, netting and glass wool will suffice.
Make sure your sub floor vents are clear to keep the void moisture free.
Fitting a DPM as described will create moisture build up and problems.
