Hello
I've browsed the forum a number of times for info (which has saved me a fortune over the years) but this is the first time I've had to post
I moved into my current house a year ago, after moving in I noticed that the bottom of one of the door frames was rotten and had been "cleverly concealed" only revealed by the wife hitting it with the hover.
This job has been on the "to do" list for some time so I cut it out yesterday, there is a central heating pipe running below the point where the frame is so I've cut back the lower part of the frame and chopped out the concrete to investigate, The wood was mostly dry but warm (from the hot pipe I'd guess) with a slight hint of moisture when rubbed between my fingers but there is no obvious signs of a leak. There is some staining on the block work behind the door frame but there's no signs of damp anywhere else in the wall
Could this have been caused by condensation or do I need to dig further, if there is a leak I suspect it'll be where the pipe bends up to the radiator which means more concrete has to come out icon_eek.gif
