Hi there...
I am having my bathroom fully tiled later this week and before it happens I wondered if it would be an idea to run the central heating piping around the central area of the room to warm the tiles a bit when the heating comes on.
The bathroom is small, so it would not be extensive. The pipe work would be under the floorboards, backing board and porcelain tiles, so hopefully this would act as a damper to prevent the floor getting too hot.
I'd also put insulation and reflective panels underneath it to try and make the most of the heat.
This is basically a rudimentary underfloor wet heating, with the only intension being that the floor isn't ice cold all winter.
Has anyone ever done/seen anything like this?
Thanks,
Steve
Thanks,
Steve
