Morning all.
Situation- replacing suspended timber floor, walls are solid full brick (9 inch)
Problem- external ground level is well above internal floor level (about 250mm), I can't risk just removing external ground because the foundations are rather shallow.
Problem 2- there isn't much of a cavity so I can't fit those natty telescopic air bricks- or not without taking out great chunks of wall and putting a lot of slips back in. Plus the brickwork isn't in brilliant condition.
Problem 3- existing airbricks are at the level of the wallplate (and too low in the outside wall)- even if I put gaps in the wallplate, the insulation (required) will obstruct them.
My thought- acquire a core drill and put 40mm or 50mm holes through the wall at about 60 degree angle (so outside the hole is about 100mm above ground, inside the hole is below wall plate and above oversite). Think I'd need 1 hole every 500mm to get acceptable airflow (40mm hole gives area of about 1200 sq mm so 2 per metre would give me 2400 sq mm, if I do 50mm that comes to about 3800 sq mm/metre)
Any thoughts? In particular building regs and that little note about 'any pipework used for ventilation must be minimum 110mm diameter'
Cheers
Cheers
