Is it safe to use polystyrene sheet insulation under a suspended wood floor?
Looking to insulated under floorboards in my living/dining room in new house ...have done so in current house and find it makes a big difference if you have laminate flooring (which I am going to have). I used netted up roll insulation attached from underside -but have large crawl space.
Problem is there is less crawl space in new house - would be really uncomfortable if not impossible so was thinking about using celotex or similar but even at seconds prices would be a hefty bill...(£300+) more than I would like to spend on this...its not that big a difference...
I have used Polystyrene sheets before -but that was behind plasterboard - it is much cheaper but I'm worried about the fire/safety aspect for under the floor ...(it will be under floorboards/fibreboard laminate insulation and laminate.) In the Wickes description they say suitable for any wall or ceiling ...no mention of floors...
B&Q sell 'Jablite floor insulation' which is thicker and more expensive but is just described as polystyrene....
