We are doing an install of 4 toilets in the basement of what will be a new bar. (Victorian Building). We cannot get the Regulation 450mm between the pan outlets as the existing 4 inch clay pipe is only 300mm below finished surface at it's lowest point before it enters public sewer. I want to run a 3 metre length of underground pipe with tees and each pan then connecting to these via short vertical drops into the underground pipe. There will be an inspection chamber at the low-point where it then runs off to the public sewer and also an AAV.
Are there regulations saying in a basement we can get away without the 450mm or that because the clay pipe is existing and we cannot change it? It is impossible to dig down further as we would be below the public sewer. (don't anyone dare mention macerators!)
