Hi, Im going to install some underground drainage under my lawn. Im looking at using 10cm perferated flexible pipe under the lawn but between the lawn and the outlet I would prefer to use normal underground pipe. Can you get an adaptor to allow you to connect the two. If not is there any solution to this.
Also, how can you prevent vermin entering the outlet pipe. Ive looked on various online shops and cannot seem to find anything that will achieve this.
Thank you for your time
Steve
Steve
