Hi guys,
I've had a good search on the forum but can't find a simple answer.
We have a log cabin in the garden we use as our daytime office. Its quite well insulated and currently use electric heaters. With the cost rising of electric we want to switch to gas for the heating, with a gas wall heater.
We have an external gas meter about 20m from the cabin down the end of our side alley attached to the house. We have paving slabs which we can dig up without too much hastle.
My plan is to have installed a Yellow Plasic MDPE gas pipe out to the log cabin. What sort of size pipe would you recommend for a 20-25m run? It's only for a gas wall heater?
I have read that the minimum depth is 375 mm. Should the MDPE gas pipe be run in a service duct pipe throughout the length? If so does this pipe need to rise above the ground at each end for ventilation?
I am just in the planning stages and other than digging the trench I plan on getting an approved Gas engineer in to do all the installation? Just interested in my options?
Appreciate the help!
Thanks.
Thanks.
