Hi all,
so after some pratting around we've identified the cause of our boiler dropping pressure every couple of hours or so. A pipe leak under the rad in the living room.....under the concrete floor
So, we've taken the decision to re-pipe all downstairs rads to above ground.
I'm planning on draining the system this weekend (as opposed to pipe freezing), so i can put full bore isolators on the 2 x 22mm pipes coming down from upstairs. I'll then put 22-15mm reducers on each pipe and then lay new 15mm above ground to each of the 2 easy to do rads. The 3rd will have to be fed from a separate rad upstairs due to its position on the ground floor.
Questions:
Thanks for any advice offered?
Questions:
- I'd like to suck all the existing water from the underground pipes prior to capping off (seeing as the leak is causing rising damp on the wall). I was looking at the sub £20 battery operated pumps, but have read mixed reviews. Obviously don't want to spend a fortune but a reasonable purchase may come in handy in the future.
- What about putting a magna clean thingy on the system somewhere? (Baxi 105e boiler in the loft if its makes any difference). We're replacing 2 very old and gunked up rads in our bedroom with one new one so might help to keep everything clean?
- Is there an advantage doing this whilst the system is drained?
