not Blue heaven!!!!! Cloud 9, but the blue cloud 9. Its the 9mm one that is called cirrus. And the difference between sound and heat insulation is so small you would never be able to tell. !
its not as good. Cloud 9 had a faulty batch a couple of years ago that was a bit noisy. However, the machine that made the faulty underlay set fire and burnt the place down. Anyway they have now changed the backing of the underlay to a soft backing.
