I had a new roof fitted 18 months ago. Where the underlay hangs into the gutter there is no UV protection. How important is this? Is it possible to fit one now the roof has been fitted?
The underlay is a breathable Klober Perme Forte and it says on the comapany website that it should have an layer of protection at the eaves because of ultra violet light. Mine doesn't and I'm PANIC stricken!!
Even when it eventually disintegrates, it will be no worse than the millions of houses that have basic bitumen and string underslating felt that has rotted outside of the fascia.All that happens is you might see the fascia above the gutter if it`s been fixed too low, and some rain might miss the gutter in the wind.there`s less chance of any damage than winning the Euromillion lottery
