We've recently bought an undermount kitchen sink to be fitted to a new solid wood worktop.
I bought the sink online here - http://www.tlc-direct.co.uk/Products/BMS020SS .html
The sink was supplied without a template, and having phoned around no template is available for it. However, the website I bought it from provides this document, featuring 'Inset Hole' dimensions - http://www.tlc-direct.co.uk/Technical/DataSheets/Baumatic_Line_Drawings/Taps/BMS020SS_Dim.pdf
The carpenter who was going to do the work is insisting that he needs a template to do it.
The suppliers of the sink say that a proper kitchen fitter would be quite at home working with just the dimensions.
Any thoughts on this? If you've looked at the .pdf you'll see that the inset hole diagram has straight-edge corners rather than rounded - is this normal? Presumably a rounded corner can still be achieved...
Thank you. Been without a kitchen worktop and sink for almost a month and it's just one obstacle after another...
