I am currently refitting a static caravan for use during a house build/renovation. The previous owners of the caravan had fitted small central heating radiators and used a combi boiler in an external shed sited adjacent to the caravan.
I have purchased the caravan but not the boiler as they have now fitted that to their new house so I need to find a suitable boiler.
The radiators are very small and I am concerned that they will not take out enough heat to stop the boiler or pipes overheating (there is some evidence this has happened in the past as some of the climaflex style pipe insulation has melted). I have calculated that the current radiators can take out approx 3kW. A few combi boilers I have looked at have minimum heat outputs of around 9kW.
So, to my questions - have I understood correctly that the minimum heat output means the minimum the radiators must take? If so, if I got a modern boiler with a suitable internal bypass, how is it different to only taking out a few kW of heat using all the radiators versus the situation in a house that may occur where say the majority of radiators' TRVs have closed off thus leaving only one or two to take the heat out of the system? Am I missing something here? Perhaps minimum heat output is to do with the Hot Water aspect of the boiler?
In general, are there modern boilers that will modulate right down and only heat the water in the heating circuit enough to meet the demands of the radiators that are fitted? Can anyone recommend one that may be suitable (and cheap) as we'll be getting rid in a year or two once the house is built (with a Ground Source Heat Pump so no need for the boiler).
Thanks.
Thanks.
