I need to replace the valves on two radiators as they drip/leak badly when the radiator is removed and I need to leave the two rads off for a week whilst a decorator is in doing some work (and I'm on holiday). So, I decided the best thing was to replace them...
I went to my tame plumbers merchant and bought four Cosmos valves but guess what they don't fit - just my luck.
The 15mm compression nut to fit to the copper is fine. But, the inlet/outlet which attaches to the tail from the rad is not a match. I have looked on various websites but can see no mention of different sizes, other than the odd 15mm x 1/2 - but I'm not clear what this means, which measurement is 1/2?
In fact, the nut on the radiator is the same size as the nut on the 15mm compression.
And yes, I've tried removing the tails from the radiator to fit the new ones supplied with the valves but can't move them at all.
Any clarification would be much appreciated.
