Hi All,
Have a fairly old Y-Plan system.
Baxi Bermuda 401 back back boiler, fully pumped (only two pipes coming from boiler.
3 Port mid positon Valve
Hot Water Cyclinder, with Water tank directly above it, which feeds into cylinder.
Smaller tank in loft that feeds CH system??
Question, does the water between the 2 systems get mixed?
For example, is water that has been flowing around the radiators going to be mixed with water in the Hot water cylinder?
So any additives added to CH system, will also go in to HW system?
Thanks!
Thanks!
