- Joined
- 17 Aug 2004
- Messages
- 21
- Reaction score
- 0
- Country
I'm trying to replace an old toilet inlet valve but having trouble with the flexible metal connector tube.
It's a bottom fill system. The fixed mains water pipe comes up from the floor and terminates with an isolator valve (which I've switched off) - it is then joined to the plastic toilet inlet valve connector by about a foot of flexible metal piping.
This has a nut at each end but if I try to unscrew the top nut (nearest the toilet) it just bends and kinks the whole flexible pipe (there's not much else to hold on to with these pipes). Not much more luck at the bottom (where it meets the mains water pipe).
I thought these flexible tubes were supposed to have free turning nuts at each end which just tightened over whatever they were connected to, and so could be unscrewed without twisting the whole pipe. Is it simply likely that the notes are very tight (goodness knows how long they've been installed and being gunked up) ?
I've tried lubricating all the joints but so far no joy. Do I need to undo both ends? Any tips for this?
