- Joined
- 14 Sep 2004
- Messages
- 15
- Reaction score
- 0
- Country
I've recently replaced an internal door in my flat, but owing to an uneven floor have had to plane off more from the bottom than I would have liked to enable the door to open past 110 degrees-ish. This means I can open it as far as I need to (just so it hits the furniture rather than jamming on the laminate floor) but means that when the door is closed, I have a gap of 3/4 inch at the bottom, which looks pants. Apart from levelling out the floor before I started, is there anything I could have done to avoid this? Also, I cut the door square, but only need the big clearance on the side of the door that swings open (the side under the lock) - not under the side under the hinges - if you know what I mean! Would it have been more sensible for me to have cut the bottom on a slight diagonal, making the 'swinging' side of the door shorter than the other side... or would it look worse to have a non-square door? I'm resigned to the fact that I'll probably have to buy a couple of fluffy rugs to go either side of the door, to hide the gap... or maybe just one to go under the door? Or would that just be weird? Any ideas/advice appreciated!
