So I had the hall, stairs and landing skimmed earlier this year and I am getting to the decorating stage.
I noticed a couple of things where the plaster meets the stringer... the plaster/wall isn't parallel to the stringer and the plaster close to the stringer is quite bumpy/poor. I am trying to hide the variation as much as possible.
I feel like quadrant isn't the best solution as it will not be parallel to the stringer and will require a lot of filling between itself and the wall where the profile of the wall varies a lot.
Shall I just scrap away/sand fill the plaster so it is at least smooth and then caulk the joint?
Some bits of the plaster are so bumpy they need scraping back with a chisel..
