Hi Everyone,
I'd really appreciate any advice you can offer on the best way to level up the first course of a small retaining wall I'm building to the front and side of my house? I dug the footings myself and had the concrete poured last week. The level is a bit out over one of the lengths (approx 30mm) over 9m. I was doing the tamping and levelling myself, so it's my own fault. The low spots are in a corner where the footing turns down the side of the house and at the opposite end of the same run, so the highest point in the middle of the run (the high point is actually slightly over the right height). I'm going to have to build up the low spots, and I could lay a thin bed at the high spot. How would you do this? Is 30mm too much to even up with mortar (3:1) in one course of block?
Also, if anybody has some general tips that would help with the project then I'm all ears! I'm not experienced so this is a fairly big project for me and I want this to be done right and done once - I don't intend to move from this house so happy to invest my time. I worked on a few sites when I was younger (just labouring) and built a couple of garden walls and generally fairly handy as a DIYer, but otherwise totally unqualified. I figured that if I take my time I could pull it off and learn some new skills along the way.
Bit of background:
Wall is retaining approx 600mm of ground which slopes towards house, and the same to side which slopes away from my house towards my neighbour. Wall will be an L shape. The slope to the front used to continue more or less down to a block path directly in front of the house wall. I want to drop the level in this area (path is only just under DPC) and profile the ground with a fall away from the house and towards the wall I'm building (3m away). The wall will allow for this drop and re-profile (hope that makes sense - hard to explain).
Length is approx 10m down the side and 9m across the front of house - there are two 150mm steps down in the length running down the side.
Footings are are 225 deep x 450 wide C35 concrete, with proper overlaps at steps. Top of footings all 150mm or more below finished ground on low side of wall. Ground is till - silt/gravel/boulders/slate etc.
I'm intending to use one course of block on flat (140mm), then engineering to DPC level on house, then F2 facing above that.
I've though about drainage and will have perforated pipe/shingle/geotextile behind and will drain to a linear soak away in the back garden.
I'd be really grateful for any thoughts or advice. Cheers!
Bit of background:
