A few months ago i gathered info from here about the unevenness of my ground floor floorboards. I used 6mm ply wood on top and the floor is looking nice and even now.
I am now moving onto the upstairs, up here unfortunately the floorboards are very uneven, some look newish and must have been replaced fairly recently. The originals are 22mm and i think the newer ones are 18mm which is obviously 4mm difference. When we moved in, it was very obvious even through the old carpet and underlay. I did plan to cover these with 6mm plywood like downstairs however i feel that over time it will just sag and show thru again.
I have considered even replacing the floors completely as all the skirtings and facings are off, however there are 2 old style partition walls that have wooden baseplates resting on the floorboards which will obviously cause difficulties to replace underneath.
So, I am thinking of boarding over with thick ply or hardboard or something lol. What would your suggestions be in this situation? If I should board over, what material and what thickness should I use? Or should i completely replace the upper floor and figure out some way to replace under the walls too.
Many thanks in advance for any advice.
Pippo
Pippo
