The Grill will ignite but not remain lit, going out as soon as the button is released. Is the problem easily fixed or do i need a gas guy to come look it over?
Have a look at the flame sensor/s. If it is covered in carbon and grease give it a clean. Otherwise it's, probably, that sensor that has packed up. You will need a gas guy, I'm guessing this is a domestic cooker rather than a gas bar b que. Either way it's probably that sensor.
