- Joined
- 24 Jan 2018
- Messages
- 2
- Reaction score
- 1
- Country
Hi all.
So I have had my RGI have a look at the boiler and we have run out of ideas.
Boiler is a Biasi M296.24SM/C
The air pressure sensor has been swapped as that was the original fault indicated by the panel lights.
Now the error message showing on the lights is “problem with ignition circuit” (solid red middle light, flashing greens, and lockout on)
RGI has cleaned the fan, and cleaned out the condensate trap, checked the ignition probes and the flame detector.
Symptoms are:
Boiler fires up on signal.
20 seconds or so later flame stops.
Loops back to beginning.
Fires back up
And repeats.
Weird part now, RGI took combustion chamber off, boiler works fine.
Put it back on, cuts out immediately!
Any known issues with these that may explain this?
Thanks.
Symptoms are:
Fires back up
And repeats.
Thanks.
