I want to put coving up in a room where a small part of the ceiling slopes down to one wall, as dictated by the roof structure, and therefore two of the internal angles (it's a square room) need to be mitred in two directions, rather than just the usual one rightish angle. I'm hoping I can use my chop saw for this, perhaps with a bevel square, as it will adjust on the two planes, but does anyone have any tips for such a task which will keep my caulking requirements to a minimum? I intend to use a polymer type rather than plaster.
When you say polymer, do you mean polystyrene or similar?
If so, burn a small piece, look at the smoke and fumes and think if this is what you want in your house if there is a fire?
More people have been killed from the smoke of this and ceiling tiles of similar (where there have been fires in places with them), than have died from the fire itself.
If you want to cove , please use your ordinary gypsum type coving, it's cheap and safe and you can fill it.
For unusual angles, use a short offcut , offer it up as close to the joint as you can ( as if it were fixed) and draw a pencil line along each edge. Take down the coving and extend the lines with a rule or doorstop etc
Do the same on the other side, so that teh lines intersect. Now you have the shape and measurements drawn on the ceiling of where your pieces need to be cut.
However - and bear with me in case I am not visualising this properly-
There is no problem with fixing the coving if it is sitting into a 90 degree angle By this I mean where the wall meets ceiling, not wall meets wall in the corner.
If you are having to cut the coving in two planes, this suggests to me that at the next joint the wall /ceiling line is splayed ie not at 90 degrees, so the coving will not sit properly into this , like the angles in a mansard roof or sloping attic room. Can you confirm this either way?
If it is only a small area in the room - can you cove up to it, finishing with an external mitre and then start again from the other side, with a mitre, or better still can you make a small bulkhead to take the coving around it?
