My kitchen is a very long way from the hot water tank and so approx 12l of water is run off each time the hot tap is used. I would like to fit a small (10l) unvented water heater under the sink and supply it from the low pressure hot water supply to the kitchen. We never use more than 5l hot water at a time and this would avoid wasting so much cold water each time.
Do I still need to fit a pressure relief valve and tundish drain to the inlet to the heater; under normal working conditions expansion will simply take place up the supply pipe which of course is open as eventually it expands into the cold water tank in the loft via the overflow from the hot water cylinder. Even if the thermostat were to fail the undersink heater would discharge into the low pressure 'hot' water supply.
Is it OK to do this? Can anyone think of a reason why not?
Thanks for your help.
