Hi All,
I'm just completing a loft conversion and had to change the initial warm deck flat roof design of the dormer to a cold deck design at the last minute due to height issues. The building control officer and architect both said this would be fine and we'll sort out the insulation later....and now it's later and I'm a little confused as to what to do for the best.
The roof in question is a flat foof dormer, around 4.5m x 3.5m, constructed with 6" x 2" timber, 18mm plywood and a 3 layer waterproof topping. The rest of the roof is pitched with clay tiles and a breather membrane.
The BCO today said it would be OK to use the multifoil insulation as a vapour barrier and he would be happy to sign that off. I want to make sure I make the right decision and have been thinking about the alternatives.
A few questions:
1) If I sprayed the spray foam insulation between the joists on to the underside of the plywood will that stop any condensation forming if moisture penetrates the insulation? I have no idea what people think of that stuff!
2) If I were to pack rockwool against the plywood, then kingspan/celotex between the joists and thin foil over would that have the same effect?
3) Should I leave a 25mm gap which vents in to the pitched roof space and allow moisture to escape that way? Or will moisture from the pitched roof space enter and condense of the flat roof ply?
4) Is there a better solution?
I'd really appreciate any advice anyone can give me as I've put my blood, sweat and tears in to this project so far and just want to do the best I can.....and not have to reroof in 10 years time!
7d
A few questions:
7d
