unvented cylinder and economy 7
25 Jan 2007
London
hi all my rare visit into here.
I have a tenented premises that has an old style meter black thing with dials with a newish consumer board. the landlord has asked me to fit a direct unvented cylinder. Obviously it would be best to get the electricity supplier to change the meter for a dualrate meter/economy7. Any idea how much this would cost.
I assume we would also need an additional board for the economy 7.
any electrical work will be carried out by nic sparkies :) not me.
Having a cylinder doesn't nessecarily mean you need eco7. Are there storage heaters?
AFAIK a supplier will change your meter for free if you go onto (or off) E7.
E7 is not any cheaper unless you use 40% or more of your total power off peak. So as Steve said, are the night storage heaters in the property?
I don't know of any suppliers where that's the case. It's normally around 15% because a typical domestic user would use 15% of his total kWh during the E7 low rate periods. Then plus an extra standing charge to cover the cost of a time or radio tele switch.
Sometimes the extra standing charge is buried in the day kWh or a primary block of kWh.
