I'm installing a new unvented cylinder.
Just filled it and tried the immersion which keeps tripping the RCD.
No trip unless the stat is adjusted to call for heat (so would that eliminate the cable?).
I bypassed the stat and connected directly to the immersion terminals with same result (so would that eliminate the stat?).
Resistance across the L & N terminals on the immersion is 20 ohms, the resistance between the L or N terminal and the E terminal is open circuit, but the resistance between the L or N terminal and the immersion base or the cylinder body is 1.8 M Ohms. Is 1.8 M Ohms enough to trip the RCD?
I've also tried powering it from three different circuits with the same result.
Any advice welcome please.
