Unvented cylinder stat wiring query
4 Jun 2008
Bedfordshire
Query: is an unvented hot water cylinder stat and thermal cut out pre-wired? Basically is the cyl stat wired up normall as per a normal 2 port valve (2 wires) and the thermal (overheat) cut out stat pre wired to the normal stat or are there different wires for this overheat stat also?
Follow the MI's and wiring diagrams for the particular un-vented you are working on ;)
