Hello
My plumber has recently installed a Worcester boiler and an Ariston unvented cylinder, 210ltr. I am also having a loft conversion.
The pipe coming from my water meter on the pavement is the copper 15mm pipe. Inside my property on the ground floor under stairs cupboard; my plumber changed the pipe from 15mm to 22mm. This runs up above to my bathroom where my cylinder sits, the rest of the pipes are 15mm. From my bathroom, the 22mm runs straight up to just before the loft conversion. The cupboard where the cylinder rest is located beneath the top end of the stairs leading to the loft conversion. The 22mm pipes go up straight but my plumber changed them to 15mm pipe across beneath the top end of the stairs and into the shower room in the loft conversion. All the pipes are 15mm in the loft conversion.
My water pressure is 3 bar in the garden. The pressure in the loft shower room in 2.5 bar but when the basin mixer is opened, the pressure reduces/drops.
The flow of the water reduces in the loft when the water is opened in the first floor bathroom. I have been told that my flow of hot water is greater than my cold water.
I was told that once the unvented cylinder goes in, I will be able to use the water/showers at the same time with no flow reduction of water.
Now my plumber tells me that this problem is due to the fact that I have a 15mm copper pipe coming into the property and I need to change it to 28mm pipe, which is another expense.
I would appreciate any help in this matter.
My question is:
Is it because my plumber did not carry the 22mm pipe into the loft shower room thats causing this problem?
Is it true that I need to change the pipe in my driveway in order to get the flow?
Is there something else we need to do to get the same flow of water everywhere?
My question is:
