Guys,
I recently had a Megaflo unvented hot water system installed in my property. I must say that I am very impressed with the results.
I do have one or two questions with how this is set up though and wonder if one of you may be able to shed light on these. The unit came with a two port valve with has been installed just after my 3 port zone valve, what puprose does this serve. When I asked the installer he said that it was a necessary safety feature and had to be installed after the 3 port valve and wired into the junction box accordingly. Surely the 3 port valve is capable of stopping the ch system from supplying heat to the cylinder?
My other question related to the removal of the cold water storage tank. When this was removed the rising mains (in 15mm) was connected to the oulet pipework that came from from the cold water tank. These 3 pipes from the tank are all in 22mm. Should this have been replaced with 15mm to each outlet they serve or is there no overall affect?
Hope this makes sense,
Terry
Terry
