Evening
Tundish is leaking on a MegaFlo UnVented tank. I have attempted to repressurise to no avail.
Having tested the water dripping down, it is cool to the touch. Can I assume it is not an immediate safety concern?
Is it right to assume the PRV is calibrated to 7bar / 90c and if the expansion was critical it would open with extremely hot water?
Either was I will get it fixed but the advice on the above would reassure me that it isn't going to at worse explode!! Until I get someone here.
I presume it's a case of replacing the PRV. The tundish is covered in limescale deposits, so I assume it is debris causing a seal failure.
