Hi all,
I recently installed an unvented indirect hot water tank in a gravity HW, pumped CH system. I changed HW pipe from 28mm to 22mm a metre or so after the boiler(Potterton e60) as tank required 22mm. CH works fine, but HW from boiler doesn't reach tank. I'm suspecting an airlock, but efforts to back flush haven't worked, possibly due to location of drain valves.
What I'm thinking now is to either add a bleed valve near highest point of HW circuit and/or moving to an S-plan system, hoping the HW pump resolves any issues with airlock and changing from 28mm to 22mm pipe (i've read on a previous post this probably was not wise).
how much effort is it converting the gravity system to fully pumped s-plan?
Any advice is much appreciated.
Thanks.
Thanks.
