Can anyone recommend an unvented indirect solar cylinder 210L for less than £900?
I've used these & I think you should buy it for under 900 sheets. Check on-line suppliers & your local Plumbers' Merchants. Also, give them a ring & ask for indie Plumbers' Merchants in your area that stock their products.
HTH
No but since the planning dep are forcing me to install some renewables this is a reasonable option.Solar hot water in this country will never pay back. Not worth it.
http://www.telford-group.com/view/tempest-solar-stainless/1390I've used these & I think you should buy it for under 900 sheets. Check on-line suppliers & your local Plumbers' Merchants. Also, give them a ring & ask for indie Plumbers' Merchants in your area that stock their products.
HTH
worcester bosch do cylinders, i ve just got one to fit with solar, it even beat plumb centre own on price and i get £100 cashback ...result!
