Unvented storage or instant gas heater
19 Jul 2008
Bath
I run a small kitchen and are looking to extend it during the autumn, increasing the number of sinks, new pass-through dishwasher etc. This will serve a 100 seat dining area.
We currently have a boiler (quite new condensing) and would like that to run a new indirect unvented cylinder (or two if it is needed). Has anyone had any experience with installing HW systems to say, a light commercial kitchen.
Will unvented storage be adequate for the demand or would a gas instantaneous heater system be better for the job?
PLEASE don't start two threads on the same subject with different information in each -
I just bashed out the following then saw your other thread which shows I wasted my time :evil:
//www.diynot.com/forums/viewtopic.php?t=142314
LOTS of things to consider here, with several potential solutions. Off the top of my head - have probably missed a few:
Resources:
  • Mains pressure flow available
    space available
    gas supply
    existing plumbing
    size of current boiler and its usage
    budget
Requirements:
  • Flow of water you need, in terms of peak flow (several taps?) and volume (to fill sinks?)
    Pressure you need - do you need force
    temperature (kitchens usually like guarantee of HOT hot water, for dealing with fatty waste)
    backup - instantaneous boilers can fail like anything else
    delay in getting hot (hot enough) water to a given tap.
You could use anything(s) from
  • instantaneous heater - one or more
    unvented storage
    thermal store
    accumulator(s)
    break tank, vented storage and pump
    secondary return
    point of use storage (eg undersink, 10 - 15 ltres)
    large water heater with store integral (eg "Andrews" type)
    a mixture
Resources:
    space available
    gas supply
    existing plumbing
    budget
Requirements:
    unvented storage
    thermal store
    accumulator(s)
    secondary return
    a mixture
Yea, sorry about starting another thread, I couldn't find the one i started originally !! I take your point, there is no right or wrong way of doing this, just a number of things to consider (which you have described... thanks).
I will have a think about it.
