I have a Vailiant EcoMax Pro 28E boiler and a megaflow unvented system.
A couple of radiators are only getting hot at the bottom. I was going to bleed them but then I read that I need to re-pressurise the system afterwards. It said that this is done by usually opening the tap on a flexibile connection, which I have found below:
However, I also read that the EcoMax boilers have a fill tap built in, which I wonder could be here?:
How do I fill the system?
Also with the heating and water off the pressure guage in the first picture was less than 0.5 bar, should it be higher than that?
